This guide will help teach you how to take off the rear wheels of your Boosted Board.
Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
Compress the motor mount back towards the wheel.
While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
Remove the axel nut with a 1/2" socket wrench
Rotate and pull counterclockwise until the wheel comes off the axle completely.
Remove the back washer from the axle.
