Boosted Board 1st Generation Belts Replacement
  1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boosted Board 1st Generation Belts Replacement, Rear Wheels: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Belts Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Belts Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boosted Board 1st Generation Belts Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Belts Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Belts Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Belts Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Belts Replacement, Belts: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Belts Replacement, Belts: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Belts Replacement, Belts: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Compress the motor mount back .
    • Slide the belt off the axle
  6. Boosted Board 1st Generation Belts Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two hex screws.
    • Remove the front hex screw.
    • When removing the Front hex screw, hold the motor mount and the truck together.
    • The springs inside the motor mount will push the motor out of the casing if they are not held together.
  7. Boosted Board 1st Generation Belts Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Belts Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Belts Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
    • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
Emily Imfeld
crwdns2935283:010/06/16crwdne2935283:0
532 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-7, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 15-7, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S15G7
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 2,043
