Use this guide to replace a speaker in the Boombotix Boombot Mini.
Twist the front panel of the speaker to the left.
Take out the four screws, then remove the panel that contains the speaker.
Take the speaker off of the base.
Expose the motherboard and place the speaker next to it.
Find the connection of the speaker by following the wires.
Now that you have found the wire connection to the motherboard, disconnect it.
Connect the white plug of the new speaker to the motherboard.
Where did you get replacement? What are the specs of the mini speaker?
