Body Panel Removal
    1. Body Panel Removal, Remove film door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push down the latch to release the film door.
    2. Body Panel Removal, Remove top cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Body Panel Removal, Remove top cover screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Body Panel Removal, Remove top cover screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove two 7.5 mm #00 screws.
      • Remove one 9.0 mm #00 screw.
      • Remove one 13.5 mm #00 screw from inside the battery compartment.
    3. Body Panel Removal, Remove top cover screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Body Panel Removal, Remove top cover screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Body Panel Removal, Remove top cover screws: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push the button to pop up the flash.
      • Remove one 3.5 mm #00 screw.
      • Remove one 5.5 mm #00 screw.
    4. Body Panel Removal, Lift top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully lift the top cover away from the body to access wired connections.
      • The top cover is still connected in several locations.
    5. Body Panel Removal, Access flash connections: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Body Panel Removal, Access flash connections: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Peel back the corner of the rubber grip.
      • Remove the small plastic cover.
      • Be careful not to short the wires before the flash capacitors have been properly discharged.
    6. Body Panel Removal, Discharge flash capacitors: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
      • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
    7. Body Panel Removal, Disconnect right flex cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully lift the sides of the white latch.
      • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
    8. Body Panel Removal, Disconnect left flex cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Desolder the red wire.
    9. Body Panel Removal, Desolder flash connections: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Body Panel Removal, Desolder flash connections: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Desolder blue, black, brown and green wires.
      • Remove the loose shim washer if present.
    10. Body Panel Removal, Desolder the flash flex cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Body Panel Removal, Desolder the flash flex cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the piece of cellophane tape covering the flex connections.
      • Desolder flex connetions.
    1. Body Panel Removal, Remove bottom cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Body Panel Removal, Remove bottom cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Body Panel Removal, Remove bottom cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
      • Remove one 5mm #00 screw.
      • Remove one 7.5mm #00 screw.
      • Remove two 4.5mm #00 screws.
      • Remove one 5.5mm #00 screw.
      • Remove the plastic frame around the accessory grip contacts.
      • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
    2. Body Panel Removal, Remove front left cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove one 4.0 mm #00 screw.
      • Remove left cover.
    3. Body Panel Removal, Remove front cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove front cover.
    4. Body Panel Removal, Unscrew front right cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Body Panel Removal, Unscrew front right cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Body Panel Removal, Unscrew front right cover: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove one 6.0 mm #00 screw.
      • Remove two 3.5 mm #00 screws.
      • Remove one 5.0 mm #00 screw.
      • Remove the strap lug.
    5. Body Panel Removal, Remove the front right cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pull the right panel away from the body. It is still attached.
      • Desolder the flex connections.
Sam Gustafson
crwdns2935283:009/01/22crwdne2935283:0
14,574 crwdns2915208:0crwdne2915208:0
crwdns2935297:078crwdne2935297:0
crwdns2942667:0crwdne2942667:0 646
