Body Cover Removal
  1. Body Cover Removal, Remove back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Body Cover Removal, Remove bottom cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Body Cover Removal, Remove left front cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Body Cover Removal, Remove front cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Body Cover Removal, Remove front cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Body Cover Removal, Remove right front cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 3.9 mm #00 screws.
Sam Gustafson
crwdns2935283:009/01/22crwdne2935283:0
7 712 crwdns2915208:0crwdne2915208:0
crwdns2935297:042crwdne2935297:0
Do you know is the leatherette is removable?
cavjer123 - crwdns2934203:0crwdne2934203:0
It should be. I haven't done it but it is a separate piece from the plastic panels. Try applying some isopropyl alcohol along an edge to soften the adhesive, then work a dull scraper underneath. It should come off without too much effort.
Sam Gustafson -
crwdns2942667:0crwdne2942667:0 397
