How to remove the covers from the body of the camera.
Push down on the screw to depress the spring loaded hinge and release the door.
Remove six 5.3 mm #00 screws.
Remove one 3.4 mm #00 screw.
Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
Remove one 7.3 mm #00 screw.
Remove the remote trigger cover.
Remove two 5.3 mm #00 screw.
Remove two 3.9 mm #00 screws.
Do you know is the leatherette is removable?
It should be. I haven't done it but it is a separate piece from the plastic panels. Try applying some isopropyl alcohol along an edge to soften the adhesive, then work a dull scraper underneath. It should come off without too much effort.
