Blu Studio Selfie Midframe Replacement
    1. Blu Studio Selfie Midframe Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure your phone is powered off.
      • Turn the front of the phone away from you.
      • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
    2. Blu Studio Selfie Midframe Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
      • Gently apply pressure until you feel the back case pop free of the phone.
      • Continue the previous two steps around the rest of the phone until the case is fully removed.
    1. Blu Studio Selfie Midframe Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Studio Selfie Midframe Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Identify the crevice at the bottom of the battery.
      • There should be enough space for you to fit your fingernail between the battery and the phone.
      • Gently lift the battery free of the phone.
    1. Blu Studio Selfie Midframe Replacement, Midframe: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove all the 4mm Phillips #000 screws from the midframe.
    2. Blu Studio Selfie Midframe Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the spudger between the midframe and the display assembly.
      • Gently pry up the midframe.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    3. Blu Studio Selfie Midframe Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Where the battery rested before, you will find a small clip that holds down the midframe.
      • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
      • Gently lift up on the clip until it comes free.
      • Remove the midframe from the phone.
Samuel McCandless
crwdns2935283:001/20/16crwdne2935283:0
170 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-1, Remmell Spring 2016 crwdns2935289:0USF Tampa, Team 10-1, Remmell Spring 2016crwdne2935289:0
USFT-REMMELL-S16S10G1
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 845
