Blu Studio Selfie Front Facing Camera Replacement
  1. Blu Studio Selfie Front Facing Camera Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Front Facing Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Front Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Studio Selfie Front Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
  4. Blu Studio Selfie Front Facing Camera Replacement, Midframe: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the 4mm Phillips #000 screws from the midframe.
  5. Blu Studio Selfie Front Facing Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger between the midframe and the display assembly.
    • Gently pry up the midframe.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. Blu Studio Selfie Front Facing Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Where the battery rested before, you will find a small clip that holds down the midframe.
    • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
    • Gently lift up on the clip until it comes free.
    • Remove the midframe from the phone.
  7. Blu Studio Selfie Front Facing Camera Replacement, Front Facing Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio Selfie Front Facing Camera Replacement, Front Facing Camera: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio Selfie Front Facing Camera Replacement, Front Facing Camera: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to lift the black tab on the ZIF connector and pull the ribbon cable out of place.
    • Using a pair of tweezers for assistance, remove the front facing camera from its case.
Stacy Kam
crwdns2935283:001/20/16crwdne2935283:0
630 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-1, Remmell Spring 2016 crwdns2935289:0USF Tampa, Team 10-1, Remmell Spring 2016crwdne2935289:0
USFT-REMMELL-S16S10G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 577
