Blu Studio HD 6.0 Power Button Replacement
  1. Blu Studio HD 6.0 Power Button Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Power Button Replacement, Back Panel.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Studio HD 6.0 Power Button Replacement, Back Panel.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Power Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Studio HD 6.0 Power Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Power Button Replacement, Midframe: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Studio HD 6.0 Power Button Replacement, Midframe: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Power Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Power Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Power Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
  8. Blu Studio HD 6.0 Power Button Replacement, Locate the power button.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The power button is located on the rear-left side of your phone just above the battery.
  9. Blu Studio HD 6.0 Power Button Replacement, Separate the old button.: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Studio HD 6.0 Power Button Replacement, Separate the old button.: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the button very carefully.
    • Then unsolder the connections.
  10. Blu Studio HD 6.0 Power Button Replacement, Solder the new button.: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Studio HD 6.0 Power Button Replacement, Solder the new button.: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Solder the new power button in the spot shown in the picture.
    • Fit the button on the side of the phone.
Ernesto Diaz
crwdns2935283:009/23/14crwdne2935283:0
1,759 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-1, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 9-1, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S9G1
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 4,716
