Blu Studio 5.5 S Rear Facing Camera Replacement
  1. Blu Studio 5.5 S Rear Facing Camera Replacement, Back Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Rear Facing Camera Replacement, Applying Pressure: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement, Applying Pressure: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement, Applying Pressure: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Rear Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Rear Facing Camera Replacement, Midframe: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement, Midframe: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement, Midframe: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Rear Facing Camera Replacement, Aesthetic Bottom Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Rear Facing Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Rear Facing Camera Replacement, Back Camera.: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement, Back Camera.: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 S Rear Facing Camera Replacement, Back Camera.: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The rear camera is located in the center of the motherboard . It is connected by a ribbon wire / prong system.
    • Use tweezers to gently pop off the prong system, by pulling upwards on the black cap piece connected to the motherboard from the ribbon wire.
    • Use the Tweezers to pull the camera out of the housing.
    • When removing the back camera be careful not to scratch the lens, unless you are throwing it out.
Cody Dyl
crwdns2935283:010/27/14crwdne2935283:0
804 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-8, Miles Fall 2014 crwdns2935289:0UMass Dartmouth, Team 4-8, Miles Fall 2014crwdne2935289:0
UMASSD-MILES-F14S4G8
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,544
