Blu Studio 5.5 Back Camera Replacement
    1. Blu Studio 5.5 Back Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the notch to remove the back panel at the lower left corner of the panel.
      • Insert the plastic opening tool or a fingernail into the notch.
      • Apply force upwards until back panel becomes loosened.
    2. Blu Studio 5.5 Back Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the loosened back panel and set aside.
      • Locate the notch to remove the battery.
    3. Blu Studio 5.5 Back Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
      • Remove the battery and set aside.
    1. Blu Studio 5.5 Back Camera Replacement, Back Panel Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement, Back Panel Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate all twelve screws along the back panel:
      • Seven 5mm screws.
      • Five 3.5mm screws.
      • Using a Phillips #000 screwdriver, remove all twelve screws.
    2. Blu Studio 5.5 Back Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
      • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
      • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
      • Remove the panel as if you were turning the page of a book.
    1. Blu Studio 5.5 Back Camera Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the motherboard that is above where the battery was removed.
      • Remove the three screws holding down the motherboard to the phone.
      • Locate all 7 flex cable connectors that are attached to the motherboard.
    2. Blu Studio 5.5 Back Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Anti-Static Wrist Strap
      $7.95
      • Use tweezers to carefully grasp and unhook all 7 flex cable connectors.
      • With the same tweezers, pry off the cable clasp that connects the motherboard to the sub PCBA.
      • Once the motherboard is disconnected from all components, use the tweezers or your fingers to remove it from the phone assembly.
      • Use the Anti-Static Wrist Strap to eliminate the possibility of introducing a static force that may damage the motherboard components.
    1. Blu Studio 5.5 Back Camera Replacement, Back Camera: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement, Back Camera: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Studio 5.5 Back Camera Replacement, Back Camera: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After the motherboard has been removed you will see the back camera, which is glued to the phone assembly.
      • Using a pair of tweezers grip onto the sides of the camera and gently pry it off the panel.
      • Make sure that when you put in the replacement it is adhered to the phone panel and the flex cable connector goes in through the motherboard opening.
Luis Gomez-Atehortua
crwdns2935283:002/28/17crwdne2935283:0
452 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G6, Nance Spring 2017 crwdns2935289:0USF Tampa, Team S1-G6, Nance Spring 2017crwdne2935289:0
USFT-NANCE-S17S1G6
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 636
