Blu L120 Rear Facing Camera Replacement
  1. Blu L120 Rear Facing Camera Replacement, Remove back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Remove back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Remove back panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
  2. Blu L120 Rear Facing Camera Replacement, Screw Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Screw Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Screw Removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove these nine screws with a small phillips screwdriver. They are all the same size.
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
  3. Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
    • *WARNING* by doing this, you will void the manufacturers warranty.
  4. Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue using the pry tool around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Rear Facing Camera Replacement, Camera Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Camera Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu L120 Rear Facing Camera Replacement, Camera Removal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pry tool to disconnect the camera from the device.
    • Gently lift the camera up and use the tweezers to remove it from the phone.
    • Reinstall the camera. Then follow the guide in reverse to put the phone back together.
Julio
crwdns2935283:010/25/14crwdne2935283:0
695 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-5, Johnson Fall 2014 crwdns2935289:0Gateway, Team 1-5, Johnson Fall 2014crwdne2935289:0
GCC-JOHNSON-F14S1G5
crwdns2942667:0crwdne2942667:0 278
