Blu Grand M2 Display Replacement
  1. Blu Grand M2 Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Grand M2 Display Replacement, Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
  2. Blu Grand M2 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
  3. Blu Grand M2 Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Grand M2 Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Grand M2 Display Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
  4. Blu Grand M2 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Grand M2 Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
  5. Blu Grand M2 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
  6. Blu Grand M2 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blu Grand M2 Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blu Grand M2 Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
Christopher
crwdns2935283:009/10/18crwdne2935283:0
192 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G3, Luster Fall 2018 crwdns2935289:0Gateway, Team S1-G3, Luster Fall 2018crwdne2935289:0
GCC-LUSTER-F18S1G3
What type of torx screwdriver did you use?
npyles86 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,840
