Blu Grand M2 Charging Port Assembly Replacement
  1. Blu Grand M2 Charging Port Assembly Replacement, Charging Port Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws with the T2 Torx screwdriver.
    • Place screws off to the side.
  2. Blu Grand M2 Charging Port Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blu Grand M2 Charging Port Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the Torx screws have been removed, use a pry tool and a suction tool to remove the back plate.
    • Using the T2 Torx screwdriver, remove the six Torx screws on the motherboard.
    • Make sure to disconnect all other connections from the camera.
  3. Blu Grand M2 Charging Port Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the motherboard assembly from the phone.
    • The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
    • Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
    • After installing the new port, repeat the steps in reverse order to reassemble the phone.
    • How to Solder and Desolder Connections
Richard Hills
crwdns2935283:009/10/18crwdne2935283:0
150 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G3, Luster Fall 2018 crwdns2935289:0Gateway, Team S1-G3, Luster Fall 2018crwdne2935289:0
GCC-LUSTER-F18S1G3
crwdns2942667:0crwdne2942667:0 619
