Blink Outdoor 4 Camera Replacement
  1. Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the mounting bracket from the device if necessary.
    • Flip the camera upside down.
    • The word 'Blink' should be at the top.
    • Insert the swivel multi-tool that was included in the Blink Outdoor 4 box into the small notch located inside the silver circle in the center of the device.
    • Twist to the left until you hear a click.
  2. Blink Outdoor 4 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blink Outdoor 4 Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry the back casing off the device.
    • Remove the two batteries and set them aside.
    • When reattaching the back casing, turn the swivel tool to the right.
  3. Blink Outdoor 4 Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blink Outdoor 4 Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all four screws near the battery compartments using a Phillips #1 screwdriver.
    • Make sure to keep track of the screws for reassembly.
  4. Blink Outdoor 4 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blink Outdoor 4 Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blink Outdoor 4 Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device on its side.
    • Use a plastic spudger to gently pry off the front cover of the device.
  5. Blink Outdoor 4 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blink Outdoor 4 Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blink Outdoor 4 Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two small black screws in the upper right corner of the board.
    • Make sure to keep the screws for reassembly.
    • Gently lift the motherboard out of the device by its edges.
    • Do not pull on the board because it's attached to some cables from underneath and it could damage the device.
  6. Blink Outdoor 4 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blink Outdoor 4 Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blink Outdoor 4 Camera Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the edges of the white camera connector and slide it out of the socket on the motherboard.
    • If that doesn't work, use the point of a spudger to push on alternating sides of the white camera connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • Remove the camera from the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Delaney Hye
crwdns2935283:002/05/26crwdne2935283:0
749 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 11-5, Weston Spring 2026 crwdns2935289:0Texas Tech, Team 11-5, Weston Spring 2026crwdne2935289:0
TTU-WESTON-S26S11G5
crwdns2942667:0crwdne2942667:0 92
