Blackview BV9800 Pro Screen Replacement
  1. Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the phone over.
    • Remove the four T5 screws.
    • Remove the single T5 screw from the bottom, next to the charging port.
  2. Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws from the sides.
    • Remove the screws holding the camera frame.
  3. Blackview BV9800 Pro Screen Replacement, Removing side bezels: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Removing side bezels: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Removing side bezels: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry out the sim car holder
    • It has a dual sim card holder, but to remove the second tray you need a pin or an iphone sim card opener to push it out.
    • Use a spudger or a utility knife to pry off the side bezels.
  4. Blackview BV9800 Pro Screen Replacement, Separate the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Separate the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry in one corner and separate the back.
  5. Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic spudger to disconnect the flex connectors.
  6. Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic spudger to disconnect the flex connector and the antenna
  7. Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat up this PCB with either iOpener or a heat gun on low temp (100-120 Celsius) to loosen the adhesive and pry it off from the side.
    • Remove the screws.
    • The last screw is under a tamper-proof sticker
    • Use plastic spudger or tweezers to disconnect the camera flex cable from the top
    • Gently lift up the plasctic cover from the right side. It is still connected to the board below!
    • Disconnect the flex cable
    • Disconnect the antenna
  8. Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws from the battery cover
    • Carefully release the ribbon cable from the battery shield. It is stuck down at two points.
  9. Blackview BV9800 Pro Screen Replacement, Disconnect connectors: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Disconnect connectors: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Disconnect connectors: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the flex connectors and remove the battery
  10. Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two J000 screws
    • Carefully pry up the camera. Heat from the glass side if necessary.
    • Unscrew and remove the camera assembly
  11. Blackview BV9800 Pro Screen Replacement, Remove light sensor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Remove light sensor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Remove light sensor: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat the light sensor from both sides to loosen the adhesive and gently pry them out of their sockets
    • Using tweezers slowly and carefully lift out the light sensor
  12. Blackview BV9800 Pro Screen Replacement, Remove audio jack: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Remove audio jack: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Remove audio jack: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use some isopropyl alcohol if necessary to loosen the glue further on the audio jack
    • Grab it with strong tweezers and wiggle from side to side and upwards until it comes out. Heat further if necessary.
    • Lift it out and transfer to the new screen.
  13. Blackview BV9800 Pro Screen Replacement, Remove ribbon cable and charging port: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackview BV9800 Pro Screen Replacement, Remove ribbon cable and charging port: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently peel the flex cable u p and transfer to the new assembly.
    • Heat it up if the adhesive is too strong.
    • Heat up and pry up the bottom PCB (charging port) and transfer to the new screen.
honakrisi
crwdns2935283:001/28/20crwdne2935283:0
3.784 crwdns2915208:0crwdne2915208:0
You saved my mobile phone. Even I did not replace the screen, I just replace the battery. I forgot some connectors but your post remind me and the mobile back to work!
Colin Wen - crwdns2934203:0crwdne2934203:0
I’m glad that you managed to save your device!
honakrisi -
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 4,938
