Blackview BV9200: Motherboard Replacement
  1. Blackview BV9200: Motherboard Replacement, Heating the LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by heating the LCD. I use a heating pad set to 100 Celsius, and let it heat for 3-5 minutes.
    • If you don't have such a tool, you should be able to use a heat gun. Just heat the edges of the screen.
    • I would not recommend trying to get the screen off without heating the glue.
    • Consider using a more appropriate tool than a part of a box cutter blade to initially separate the LCD from the frame. (I would've tried using iFixit's Jimmy, but I haven't got it yet)
    • Be very careful if you use a part of box cutter blade. You could easily tear the LCD's cables or scratch the underside.
    • Be careful not to separate the LCD and touch panel. When removing the glue with a plastic card, either go underneath the LCD as well or only on the edges of the touch panel.
    • The video is sped up to fit within the 30 second limit. Do it slower and more carefully.
  2. Blackview BV9200: Motherboard Replacement, LCD's connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, LCD's connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, LCD's connector: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the screw, remove the tab, unplug the LCD and pull it off.
    • I use tweezers to get the little tab that covers the connector out.
  3. Blackview BV9200: Motherboard Replacement, Screeeeeeeews.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Screeeeeeeews.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Many screws.
    • Ones circled in red are all the same size, and ones circled in yellow are the same size as the one which held the tab that covered the LCD connector.
    • After you remove the screws, get leverage on the bottom. You will see a small indent where you can squeeze a tool in.
  4. Blackview BV9200: Motherboard Replacement, Removing the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Removing the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Removing the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cover.
    • Remove the cable. Connectors are pointed at by arrows.
    • Disconnect and remove the battery.
    • The battery is not glued or screwed in. Simply grab a hold of it and lightly pull it out.
  5. Blackview BV9200: Motherboard Replacement, Cat: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Meow.
  6. Blackview BV9200: Motherboard Replacement, Removing peripherals off the motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the connectors, the cameras and the screws that are pointed to.
    • Tweezers or plastic cards work well for removing connectors here.
  7. Blackview BV9200: Motherboard Replacement, Removing the motherboard from the case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Removing the motherboard from the case: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Removing the motherboard from the case: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The motherboard assembly is held in place by 2 latches. Get it unlatched.
    • Once you have it unlatched, pull it slightly towards you, then bend it over so you can see the underside.
    • Disconnect the data cable.
    • Be careful when doing this, as these cables are fragile and it is very easy to tear their heads off.
  8. Blackview BV9200: Motherboard Replacement, Taking off the housing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Taking off the housing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The plastic housing is held in place by 2 latches and a screw we removed in step 1.
    • After you get it apart, remove the cameras from the motherboard.
  9. Blackview BV9200: Motherboard Replacement, Reassembling the motherboard assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Reassembling the motherboard assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the connector off the auxiliary PCBA that is found on the housing.
    • Attach the MB side on the new motherboard, then attach the cameras.
  10. Blackview BV9200: Motherboard Replacement, Prepping motherboard to put back into the case: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Prepping motherboard to put back into the case: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reattach the connector on the auxiliary PCBA.
    • Attach the data cable.
    • This wasn't outlined in the previous steps, but detach the data cable from the USB board to make these and following steps easier.
  11. Blackview BV9200: Motherboard Replacement, Backpacks are good chairs.: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Meow.
  12. Blackview BV9200: Motherboard Replacement, Reinserting the motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Reinserting the motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Reinserting the motherboard: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the cables out of the way.
    • Attach the bottom part of the cable that is connected to the USB board.
    • Attach the top part of the cable.
  13. Blackview BV9200: Motherboard Replacement, Reassembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Reassembly: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Reassembly: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screw in the screws.
    • Attach all the connectors, and the cameras. Then, insert the battery and attach it. Lastly, add the final connector between the USB board and motherboard.
    • Do not forget to re-attach the data cable.
  14. Blackview BV9200: Motherboard Replacement, Final steps: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Final steps: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackview BV9200: Motherboard Replacement, Final steps: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert the cover panel, and screw in the screws.
    • Attach the LCD connector and cover it with the tab.
    • Glue the screen to the case.
Make sure to use good glue to preserve waterproofness and dustproofness of the product.
DegenFixer
crwdns2935283:009/18/24crwdne2935283:0
4,661 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 209
