Remove the back cover of the phone
Unscrew the four screws using the T6 screw driver
Remove front silver trim by using plastic opening tools and wiggle it off.
Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
Use the plastic removal tool to remove the entire back cover.
Unplug the black antenna wire from the logic board.
Peel off the three ribbon cables
The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
Take out your logic board
Unscrew six small gold screws
Separate the screen from its frame
Remove gold sticky film that attaches the digitizer to the screen
Separate the digitizer from its screen
Move the digitizer to remove both circled screws with a T-4 bit.
The screw in red is under the screen, be careful of the ribbon cable in the top left corner.
Remove the circled screws with a T-2 bit.
Use a plastic opening tool to separate the assembly.
This ribbon cable comes out with a simple tug.
Pull the digitizer off the face of the phone and carefully guiding the ribbon cable out of the slot.
Remove the screen using the opening tools.
Superb wish I could get the heating instrument can u just describe?
