Remove the back cover of the phone
Unscrew the four screws using the T6 screw driver
Remove front silver trim by using plastic opening tools and wiggle it off.
Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
Use the plastic removal tool to remove the entire back cover.
Unplug the black antenna wire from the logic board.
Peel off the three ribbon cables
The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
Take out your logic board
crwdns2935229:05crwdne2935229:0
