Remove the back cover of the phone
Unscrew the four screws using the T6 screw driver.
Slide the screen up.
Remove front silver trim by using a plastic opening tools and wiggle it off.
Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
Use the plastic opening tools to remove the entire back off the phone.
Remove the three ribbon cables and the antenna wire by hand.
The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
The logic board will easily pull straight out.
Remove the black sticker located above the logic board that contains the phone's serial number
Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
Carefully separate the screen from the body.
Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
They are on a black cover located on the bottom of the phone. The black cover will come off
There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
Push the cursor upwards and out of the socket.
Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
