Blackberry Storm 9530 Battery Replacement
  1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
melanie lim
crwdns2935283:004/22/14crwdne2935283:0
607 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-16, Regan Spring 2014 crwdns2935289:0Cal Poly, Team 9-16, Regan Spring 2014crwdne2935289:0
CPSU-REGAN-S14S9G16
crwdns2942667:0crwdne2942667:0 1,886
