This guide will be useful in replacing the keyboard for the Blackberry RIM 7250. For this guide, you will need a plastic opening tool and a Torx #6 screwdriver head.
Push the release button down and away from the device.
Slide the cover off toward the bottom of the device, revealing the battery compartment.
Place your finger in the groove next to the battery.
Lift your finger up to eject the battery from the battery compartment.
Remove the battery from the compartment.
Remove the four 10.7 mm Torx T6 screws.
Hold the phone with one hand, with the bottom facing toward you.
For both clips, insert the plastic opening tool and push away from you.
Grab the back housing from the bottom and lift the housing away from you.
Place your thumb on the bottom rectangle and your index finger on the top rectangle.
Squeeze your fingers together to release the internals from the front housing.
Pull the two pieces apart to separate the front housing from the internals.
Push the keyboard from the front view to separate it from the front housing.
Hold the front housing with one hand and grab the keyboard with the other.
Pull each piece away from each other to remove the keyboard.
