Blackberry Curve 9300 Screen Replacement
  1. Blackberry Curve 9300 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Screen Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry Curve 9300 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Screen Replacement, Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
  11. Blackberry Curve 9300 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the keyboard base up and away from the phone.
    • Disconnect the keyboard base from the phone completely.
  12. Blackberry Curve 9300 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry Curve 9300 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry Curve 9300 Screen Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry Curve 9300 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • The opening tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry Curve 9300 Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry Curve 9300 Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry Curve 9300 Screen Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
crwdns2935229:09crwdne2935229:0
Alek Squires
crwdns2935283:009/30/13crwdne2935283:0
431 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-7, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 14-7, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S14G7
would appreciate new ldc part # and order info! - - !
Donald Burgo - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,945
