This guide is designed to help consumers replace their Blackberry Curve 9300 keyboard.
Place your Blackberry face down in front of you.
Locate the indent on the bottom of the back cover.
Use your fingernail to lift and remove the back cover.
From the top, use your fingernail to lift and remove the battery.
Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Place the phone face up and use tweezers to securely grip and lift the screen upwards.
Use a plastic opening tool to lift the bottom edge of the front cover.
Use your nails to unclip the sides of the frame from the phone.
