Blackberry Curve 8320 Keyboard Replacement
  1. Blackberry Curve 8320 Keyboard Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry Curve 8320 Keyboard Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry Curve 8320 Keyboard Replacement, Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  2. Blackberry Curve 8320 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry Curve 8320 Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  3. Blackberry Curve 8320 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry Curve 8320 Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  4. Blackberry Curve 8320 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  5. Blackberry Curve 8320 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  6. Blackberry Curve 8320 Keyboard Replacement, Keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry Curve 8320 Keyboard Replacement, Keyboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the keyboard.
    • Be careful not to bend or fold the keyboard, as it can break easily.
Yegor Pomortsev
crwdns2935283:010/12/11crwdne2935283:0
123 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-6, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 3-6, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S3G6
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,140
