Blackberry Classic digitizer Replacement
    1. Blackberry Classic  digitizer Replacement, Digitizer assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Start by removing the back cover.
      • It's glued on the top and at the bottom. Use an isesamo and gentle force to remove it
    2. Blackberry Classic  digitizer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Like many other blackberry models, lift out the small plastic edge at the bottom of the keyboard
      • This will reveal two torx screws to remove
    3. Blackberry Classic  digitizer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the blackberry around and remove all torx screws
      • Separate the battery screws as they are different
      • Watch out for the 00 Philips screw on the top left corner
      • Remove the plastic mid-frame
    4. Blackberry Classic  digitizer Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The battery is held firmly by glue (or space putty?)
      • That 4$ card proved its utility
      • Be careful when removing the adhesive not to pry the small connectors at the base of the board.
    5. Blackberry Classic  digitizer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The board is clipped and lightly glued. Use tweezers to lift the retention clips under the board to release it.
    6. Blackberry Classic  digitizer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the micro usb connector, the audio jack and the 3 ph000 screws on the board.
      • This will allow you to push out the metal mid-frame
    7. Blackberry Classic  digitizer Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once screws are all out, gently lift the broken digitizer. Make sure to lift between the display assembly and the black border.
      • Remove any remaining shattered glass from the display frame before reassembling.
      • Reassemble in reverse order
crwdns2935229:023crwdne2935229:0
coutureg
crwdns2935283:007/19/12crwdne2935283:0
885 crwdns2915208:0crwdne2915208:0
Techno-sos crwdns2935289:0Techno-soscrwdne2935289:0
Business
crwdns2947412:09crwdne2947412:0
If I’m just switching boards, is it even necessary to remove the battery? Can’t I just switch the boards with the batteries still attached to their respective boards? I just don’t see the point of removing the battery unless you are replacing it.
gary - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If you are replacing the board and the battery, and can reach the retention clips under the board to lift the board out of the case, I guess it could be possible to replace both parts without separating them.
coutureg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
So I can confirm that you do not need to remove the battery to switch the boards. You can leave it stuck to the board.
https://imgur.com/a/FtY09en
Interesting, thanks for the update ! Cheers !
You are welcome! Thanks for the great writeup coutureg
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 127
crwdns2942667:0crwdne2942667:0 18,189
