Replacing the BlackBerry Bold 9900 battery is the simplest replacement on the phone. All you need is to pry a little bit with your fingers. Replacement of the battery will improve battery life.
Place phone screen down.
Use your finger to life upward on the battery case.
Pull the cover away from the battery.
Lift the edge of battery with the green stripe upward to remove battery.
