Blackberry Bold 9650 Keypad Replacement
  1. Blackberry Bold 9650 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry Bold 9650 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Keypad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Keypad Replacement, SIM Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Keypad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Keypad Replacement, Back Chassis: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Keypad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Keypad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Keypad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Keypad Replacement, Mother Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 Keypad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 Keypad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 Keypad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the mother board by lifting the board upward.
  13. Blackberry Bold 9650 Keypad Replacement, Faceplate: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry Bold 9650 Keypad Replacement, Faceplate: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
  14. Blackberry Bold 9650 Keypad Replacement, Keypad: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the keypad out of the the front cover.
Ryan
crwdns2935283:003/12/12crwdne2935283:0
696 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Clemson, Team 2-5, Benson Spring 2012 crwdns2935289:0Clemson, Team 2-5, Benson Spring 2012crwdne2935289:0
CLEM-BENSON-S12S2G5
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 7,294
