Blackberry Bold 9000 Volume Toggle Replacement
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Volume Toggle Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Volume Toggle Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM card.
  5. Blackberry Bold 9000 Volume Toggle Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Volume Toggle Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Volume Toggle Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Blackberry Bold 9000 Volume Toggle Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
Kelly
crwdns2935283:001/18/12crwdne2935283:0
566 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-17, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 8-17, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S8G17
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 2,525
