If you are removing or replacing the Blackberry 7520 LCD screen, look here for support.
Turn the phone upside down.
Push down on the black button on the back of the phone to slide the rear panel off.
The battery should be visible now.
Hold the BlackBerry in one hand face-up with the screen facing towards you.
Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
Use a pick or plastic opening tool to push the clips holding the rear away from you.
Repeat the process of unlatching the clips for the top section of the Blackberry.
Slide the rear panel forward to reveal the motherboard.
Remove the indicated screws using a T6 Torx screwdriver.
Remove the motherboard.
Remove the indicated screw using the T6 Torx screwdriver.
Pull the metal plate away from the front panel of the cell phone.
Place the faceplate face-down and the interior of the phone face-up, as shown.
Turn the phone so that it faces towards you.
Use a pick or other small tool to pop the small plastic clip holding the LCD panel on
Pull the LCD screen off of the board.
It’s too bad that iFixit didn’t post a teardown listing the parts for the BlackBerry 7520, since so little is known about its parts.
amosbatto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
