Blackberry 7105t Keyboard Replacement
  1. Blackberry 7105t Keyboard Replacement, Blackberry 7105t Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry 7105t Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry 7105t Keyboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t Keyboard Replacement, Second Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • Warning: Some of the phones have an adhesive between the silver part and the battery housing, so it could stick to the black piece you just removed.
  9. Blackberry 7105t Keyboard Replacement, Keyboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry 7105t Keyboard Replacement, Keyboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to lift up the two black clips indicated in the picture.
    • Hold on to the keyboard while unfastening the clips.
    • The keyboard will detach once the clips are unfastened.
CeeJay
crwdns2935283:010/28/09crwdne2935283:0
19 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-17, Regan Fall 2009 crwdns2935289:0Cal Poly, Team 9-17, Regan Fall 2009crwdne2935289:0
CPSU-REGAN-F09S9G17
crwdns2942667:0crwdne2942667:0 2,912
