Guide for the replacement of the middle frame that includes Power Button, Audio Jack and Microphones
Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
Remove the SIM card and the Media SD card by pushing on them.
Locate and unscrew all 10 T5 screws around the back cover
Use Plastic opening tools to separate the LCD from the Main body
Use a plastic tool to carefully switch up the LCD ribbon holder
Detach the LCD from the main board
You can now detach the LCD Panel from the main frame.
With a plastic tool, untie the system board by detaching the ribbons attached to it
The battery ribbon is on the bottom right
Power Button /Audio Jack
Flash
Rear Facing Camera
Once all Ribbons untied, gently wiggle the system board out of the frame
Use a pair of pliers to remove the rear facing camera
Re-Assemble the unit using the new middle frame.
