BlackBerry Z30 Logic board Replacement
  1. BlackBerry Z30 Logic board Replacement, Battery cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Logic board Replacement, Remove SIM and Media Card: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Logic board Replacement, Remove the LCD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Z30 Logic board Replacement, Remove the LCD: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Logic board Replacement, LCD Panel removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Logic board Replacement, Untie the System board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Logic board Replacement, Untie the System board Part 2: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Logic board Replacement, Untie the system board Part 3: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Logic board Replacement, System board removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
Hans
crwdns2935283:010/20/14crwdne2935283:0
1,926 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 4,201
