Flip the phone on its front.
Remove the top SIM/microSD card cover by the notch.
Remove the top two 7 mm screws using a T4 Torx screwdriver.
Remove the bottom three 5 mm screws using a T4 Torx screwdriver.
Remove the cover located under the keyboard.
Remove the two 6 mm screws using the T4 Torx screwdriver.
Remove the black tape from the battery and the motherboard.
Remove the five 4 mm screws using a T4 Torx screwdriver.
Remove the two 3 mm screws using a T4 Torx screwdriver.
Disconnect the left four connectors.
