BlackBerry Curve 8900 Battery Replacement
  1. BlackBerry Curve 8900 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover of the phone.
    • The battery will now be visible.
    Pry off the back and separate it from the front of the phone case. You should see the battery once you pry the back off.
    (rewriting the second sentence)
    You will see the battery once the cover is removed.
    Aubrey - crwdns2934203:0crwdne2934203:0
  2. BlackBerry Curve 8900 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8900 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
    On both sides of the battery, there is a lighter grey half-circle. This is the best place to use your fingers to gently lift the battery free of the housing. Set aside the old battery, then replace it with the new battery. It should easily fit into place.
    (deleted "it sits in") from second sentence
    Replace backing of phone, pressing gently to secure to back of phone case ( There seems to be a bit of repetition in this sentence so I rewrote it.)
    Reattach the back cover by pressing gently until cover is secure.
Set aside the old battery, then replace it with the new battery. It should easily fit into place. Then, you can replace the backing of phone, pressing gently to secure it down.
Renae Bishop
crwdns2935283:009/07/11crwdne2935283:0
68 crwdns2915208:0crwdne2915208:0
Cuesta, Team 1-3, Zipperian Fall 2011 crwdns2935289:0Cuesta, Team 1-3, Zipperian Fall 2011crwdne2935289:0
CUESTA-ZIPPERIAN-F11S1G3
crwdns2942667:0crwdne2942667:0 3,410
