BlackBerry Curve 8900 Antenna Replacement
  1. BlackBerry Curve 8900 Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Antenna Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lower rear cover, using a small iFixit opening tool.
  4. BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
    • Set the screws aside once they've been removed.
  5. BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the mid-frame from the phone, exposing the motherboard.
    • This is the motherboard.
  6. BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull back the plastic tabs that secure the motherboard to the case.
    • Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall off the motherboard.
  7. BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Disconnect the antenna from the motherboard in the same manner.
  8. BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the chip underneath the screen.
    • Gently remove the screen, without applying too much pressure, taking care not to damage it.
  10. BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8900 Antenna Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the motherboard from the bottom edge to reveal the ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
    • Remove the motherboard and place off to the side.
  11. BlackBerry Curve 8900 Antenna Replacement, Antenna: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the entire center piece of the case to replace the antenna.
Once all the steps have been completed, reassemble the device in reverse order.
Johnny Tran
crwdns2935283:009/10/11crwdne2935283:0
473 crwdns2915208:0crwdne2915208:0
Cuesta, Team 1-3, Zipperian Fall 2011 crwdns2935289:0Cuesta, Team 1-3, Zipperian Fall 2011crwdne2935289:0
CUESTA-ZIPPERIAN-F11S1G3
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 6,027
