BlackBerry Curve 8520 LCD Screen Replacement
  1. BlackBerry Curve 8520 LCD Screen Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 LCD Screen Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 LCD Screen Replacement, Keyboard Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement, Keyboard Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
  7. BlackBerry Curve 8520 LCD Screen Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8520 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
crwdns2935229:012crwdne2935229:0
Matt
crwdns2935283:004/07/11crwdne2935283:0
1,764 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-62, Walters Spring 2011 crwdns2935289:0Cal Poly, Team 9-62, Walters Spring 2011crwdne2935289:0
CPSU-WALTERS-S11S9G62
crwdns2942667:0crwdne2942667:0 36,072
