            Press down on the battery release button and slide the back cover up with your thumb.
            Pry from the top of the battery to pull it out.
            Slide the metal sim card cover to the unlock position.
            Remove the sim card.
            Remove the two T5 Torx screws circled at the top of the phone.
            Remove the red cover at the bottom of the phone.
            Use a spudger to pry the front cover away from the side panels.
            Work the spudger around the entire phone until the front cover is free.
            Use a spudger to pry off the plastic ring surrounding the trackball.
