Press down on the battery release button and slide the back cover up with your thumb.
Pry from the top of the battery to pull it out.
Slide the metal sim card cover to the unlock position.
Remove the sim card.
Remove the two T5 Torx screws circled at the top of the phone.
Remove the red cover at the bottom of the phone.
Use a spudger to pry the front cover away from the side panels.
Work the spudger around the entire phone until the front cover is free.
Remove the four T6 Torx screws located on the corners of the keyboard frame.
Now remove the left and right side panels.
Remove the keyboard frame.
Now remove the screen housing.
Unplug the ribbon cable from the board.
Insert tool between LCD screen and board.
Pry LCD screen from board.
