BlackBerry 8820 Trackball Replacement
  1. BlackBerry 8820 Trackball Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
  2. BlackBerry 8820 Trackball Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Trackball Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Trackball Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Trackball Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the two plastic side bars using a nylon spudger.
  4. BlackBerry 8820 Trackball Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
  5. BlackBerry 8820 Trackball Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Trackball Replacement, Track Ball: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the front from the outer casing, the track ball will come off attached to the casing.
  7. BlackBerry 8820 Trackball Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the track ball from the front case.
ryan
crwdns2935283:004/12/13crwdne2935283:0
44 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-64, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-64, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G64
crwdns2942667:0crwdne2942667:0 942
