BlackBerry 8820 Trackball Replacement
    1. BlackBerry 8820 Trackball Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
    2. BlackBerry 8820 Trackball Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Trackball Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the battery by prying under it with your finger or a plastic opening tool.
      • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
    3. BlackBerry 8820 Trackball Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Trackball Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully remove the two plastic side bars using a nylon spudger.
    4. BlackBerry 8820 Trackball Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pry the back casing off with a nylon spudger.
      • There are two small clamps on each edge that need to be unhooked before the casing can come off.
    5. BlackBerry 8820 Trackball Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off the front casing.
      • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
    1. BlackBerry 8820 Trackball Replacement, Track Ball: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After removing the front from the outer casing, the track ball will come off attached to the casing.
    2. BlackBerry 8820 Trackball Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the track ball from the front case.
ryan
crwdns2935283:004/12/13crwdne2935283:0
44 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-64, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-64, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G64
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 1,416
