BlackBerry 8820 Motherboard Replacement
  1. BlackBerry 8820 Motherboard Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
  2. BlackBerry 8820 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the two plastic side bars using a nylon spudger.
  4. BlackBerry 8820 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
  5. BlackBerry 8820 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom casing clip, which will easily unsnap when pulled.
  7. BlackBerry 8820 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook both sides of the white wire from the motherboard using the plastic opening tool from before.
  8. BlackBerry 8820 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the gloss SATA cable strap connecting LCD screen at the top of the phone.
    • Detach this cable by levering under the connector with a prying tool.
    • Handle with care when removing the ribbon cable handle, it is prone to breaking.
  9. BlackBerry 8820 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • WARNING: Be sure to have disconnected the SATA cable strap before attempting.
    • Using the prying tool, lever the old screen up as shown.
  10. BlackBerry 8820 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 8820 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 8820 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There will be two small clips on each side of the motherboard. Unhook each clip one at a time using the plastic opening tool.
    • Once all four clips are unhooked you should be able to pull the motherboard from the casing with your hands.
    • After removing the old motherboard, you can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order. After replacing your BlackBerry's motherboard with a new one, recycle the old motherboard at an [[E-Waste#:~:text=Those%20dead%20parts%20should%20go,be%20put%20in%20the%20trash.|electronics recycler|new_window=true]].
ryan
crwdns2935283:004/12/13crwdne2935283:0
44 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-64, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-64, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G64
crwdns2942667:0crwdne2942667:0 985
