BlackBerry 8820 LCD Screen Replacement
  1. BlackBerry 8820 LCD Screen Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
  2. BlackBerry 8820 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the two plastic side bars using a nylon spudger.
  4. BlackBerry 8820 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
  5. BlackBerry 8820 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 LCD Screen Replacement, LCD Screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After disassembling the outer casing, the phone should be stripped as shown.
  7. BlackBerry 8820 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, disconnect the SATA cable by levering under the connector.
  8. BlackBerry 8820 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, pry up the old screen as shown.
    • Be sure that the SATA cable is disconnected prior to attempting this.
  9. BlackBerry 8820 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8820 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the new LCD screen.
    • Attach the cable to the connector located at the top of the phone.
ryan
crwdns2935283:004/12/13crwdne2935283:0
44 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-64, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-64, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G64
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 776
