This guide will show you how to replace the keyboard of the BlackBerry 8820. In order to do so, you must have a 1/16" diameter torx screwdriver and a plastic opening tool.
Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
Remove the battery by prying under it with your finger or a plastic opening tool.
Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
Carefully remove the two plastic side bars using a nylon spudger.
Carefully pry the back casing off with a nylon spudger.
Slide the keyboard downwards, as shown.
The keyboard will detach from the casing with a small amount of pressure.
Slide the new keyboard into the casing. If done correctly, it should click into place and stay secure.
