crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0BlackBerry 8700ccrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. BlackBerry 8700c Teardown, BlackBerry 8700c Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In this first step you will remove the battery cover by pushing down on the button on the cover and sliding towards the bottom of the phone.
    • To do this unscrew all four T6 screws
    • Once this is done gently remove the back cover of the phone by pulling first from the bottom towards you, then from the top upwards.
  2. BlackBerry 8700c Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery, place your fingernail in the slot at the top right of the battery and pull up.
  3. BlackBerry 8700c Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 8700c Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 8700c Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, remove the back portion of the phone by removing four T6 Screws.
    • Once the screws have been removed, firmly grab the back cover and pull back from the front cover.
  4. BlackBerry 8700c Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8700c Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the middle portion of the phone you will again remove four T6 screws.
    • Follow the removal of the screws, you can now pull the front face plate away from the middle portion.
  5. BlackBerry 8700c Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8700c Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Follow the removal of the screws, you can now pull the middle portion away from the main logic board.
    • Next, hold the logic board and remove the front face plate of the phone
  6. BlackBerry 8700c Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8700c Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When the front face plate has been pulled away, be sure to grab the keypad as it may fall out.
  7. BlackBerry 8700c Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 8700c Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, use a metal spudger to unhook the earpiece from the inside of the front panel.
  8. BlackBerry 8700c Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 8700c Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 8700c Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a metal spudger, push back on the four clips holding the LCD screen to the logic board.
    • Next gradually pull the screen away from the board so that none of the clips are engaged.
    • Last, use a metal spudger to push back on the clip locking in the ribbon cable for the screen.
  9. BlackBerry 8700c Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen is now fully detached, and the phone is completely disassembled.
k3nt
crwdns2935283:010/28/09crwdne2935283:0
42 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-4, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 18-4, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S18G4
crwdns2942667:0crwdne2942667:0 6,633
