BlackBerry 7130e Disassembly
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. BlackBerry 7130e Disassembly, BlackBerry 7130e Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T6 Torx screwdriver, remove the bottom two screws on the back of the phone.
  2. BlackBerry 7130e Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove speaker phone cover by unsecuring the two latches on the edge close to top of the phone with the plastic opening tool.
  3. BlackBerry 7130e Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the speaker phone cover by pulling up on the bottom of the speaker phone cover.
    • As you detach the speaker phone cover you will notice a sticky glue sealing the rubber gasket from the cover to the speaker mesh. This is normal and will correctly reset the first few times the pieces are separated.
  4. BlackBerry 7130e Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove top two screws with T6 Torx screw driver, from the back of phone.
  5. BlackBerry 7130e Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the phone sideways and unlatch the hinge on one side of the phone by pushing inwards and twisting to the side with the plastic opening tool.
  6. BlackBerry 7130e Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 7130e Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You should now be able to easily separate the phone into two pieces.
    • The battery prong may fall out when the separation occurs, just don't loose it!
Sean Tiernan
crwdns2935283:001/20/10crwdne2935283:0
5 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-16, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 3-16, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S3G16
crwdns2942667:0crwdne2942667:0 1,007
