BlackBerry 7100g Screen Replacement
  1. BlackBerry 7100g Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Screen Replacement, Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement, Housing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement, Housing: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 7100g Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now easily remove the "guts" of the phone from the housing.
  8. BlackBerry 7100g Screen Replacement, Keypad: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement, Keypad: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement, Keypad: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the "guts" over so the speaker is facing up.
    • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
    • Separate the battery housing from the motherboard.
  9. BlackBerry 7100g Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the keypad off of the motherboard.
    • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
  10. BlackBerry 7100g Screen Replacement, Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 7100g Screen Replacement, Screen: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the ribbon connector below the bottom of the screen.
    • Use a spudger to flip up the connector.
  11. BlackBerry 7100g Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 7100g Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the four (4) white tabs that attach the screen to the motherboard.
    • Carefully detach the tabs from the motherboard.
    • The screen can now be removed from the motherboard.
Adriel Salinas
crwdns2935283:004/11/10crwdne2935283:0
42 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-87, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 25-87, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S25G87
crwdns2935297:017crwdne2935297:0
just a heads up don't do this with a iPhone it does not work at All!
Jaxson HUTCHINSON - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,965
