This guide shows how to replace the BlackBerry 7100g external housing case.
Turn over your BalckBerry 7100g so that the back cover is facing up.
Locate the battery cover release button near the bottom of the back panel.
Push down on the release button with one thumb.
Slide the battery cover off with the other thumb.
Remove the battery from the battery housing by flipping up the top of the battery.
Locate the silver strip near the top of your BlackBerry.
Use a plastic opening tool to pry off the edge of the silver lining.
Slide the tool along the length of the silver strip to completely remove it.
Locate and unscrew the four (4) screws using a T6 screwdriver.
Tightly pinch the top of the front and back halves of the housing.
Carefully pry the two halves of the housing apart.
You can now easily remove the "guts" of the phone from the housing.
