Detailed steps to disassemble an RT550, explanation of how the sliding power switch activates the device, demonstration of how I fixed the power switch by using a piece of cardboard to slightly raise the internal power button and a few tips and warnings along the way so you can successfully reassemble.
crwdns2936621:0crwdne2936621:0
Detailed steps to disassemble RT550 and correct problem with power switch. Watch it once before you attempt, there are a few tricky parts.
Work on a clean surface to avoid losing parts
Notice laying the tool flat before separating the two halves
Explanation of the sliding power switch mechanism
How I fixed the power switch not contacting the actual power button
Wrapping up, do steps in reverse to reassemble.
