Black and Decker WP900 Motor Replacement
  1. Black and Decker WP900 Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker WP900 Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker WP900 Motor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker WP900 Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the power cord out from the control module.
    • Remember, when you're reassembling the device, the black wire should be on the top.
  6. Black and Decker WP900 Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel are attached to the motor.
  7. Black and Decker WP900 Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker WP900 Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the two 22mm screws securing the brush assembly to the motor.
  8. Black and Decker WP900 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker WP900 Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To fully remove the brush assembly from the motor, push the brushes (enclosed in the gold ribbing) outward and pull up.
  9. Black and Decker WP900 Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a large amount of force, pull the motor up and off of the wire coil.
Stefan Wolowec
crwdns2935283:002/15/16crwdne2935283:0
128 crwdns2915208:0crwdne2915208:0
IUPUI, Team 8-8, Wilson Spring 2016 crwdns2935289:0IUPUI, Team 8-8, Wilson Spring 2016crwdne2935289:0
IUPUI-WILSON-S16S8G8
Very straightforward tutotial. We are writing review of this product here https://www.helpful.reviews/en/product/4.... However we have not found many cases among owners of this product that they would need to repair motor by its replacement.
John Bazmek - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 2,546
